Other Parts Discussed in Thread: DRV8838
Hi team,
Does DRV8837 have installed dead-time control in brake mode ? It seems to cause a short circuit by putting high levels into both IN1 and IN2
Thank you!
Hi Troyson,
Dead time is inserted as the device switches from low to high or high to low.
Can you provide more details?
Why do you think there is a short circuit condition?
Do you have any scope captures showing the short circuit (voltages at both outputs plus current)?
What is your load and how is it configured?
Hi Troyson,
We have not heard from you in some time and are assuming your issue has been resolved.
If it has not please reply to this thread, or if this thread has been locked select "+Ask a related question" at the top right of the page.
Hi Rick:
My ctm is doubt that it doesn't say how dead-time control work in datasheet. They will use brake mode which will face with dead-time control. They need TI can ensure the circuit short will not happen when they use brake mode.
Thank you !
Hi Troyson,
Although the datasheet does not specifically state this, the DRV8837 and DRV8838 have dead time control integrated into the device.
A handshaking circuit monitors the FETs when switching.
Once the high side monitor determines the high side FET is off, then the low side can be enabled.
A similar monitor is on the low side to prevent the high side turning on prematurely.
