HI Team,
if i made chip as DRVOFF when i again make ON shall i need update the registers as per requirement .
In Sleep case not needed is this correct?? (Registers are as my init already done)
HI Team,
Hi Sravan,
If I understand your question, the SPI registers do not change when DRVOFF is set high then low. There is no need to update the registers.
If the device is placed into sleep mode and then exits sleep mode, the registers are set to the default values. In this case, the registers should be written to the desired values.
