Hello?
now RV8711 Can Run. 1/256 micro Step. 400 RPM.
if 450 RPM or More.... motor is Slip....
What is Max RPM?
My Target RPM is 1500 RPM...
How Can I Setup?
Sorrymy english.
Thank you.
Hello?
What is Max RPM?
How Can I Setup?
Sorrymy english.
Thank you.
Sanghyouk,
"if 450 RPM or More.... motor is Slip...." I would think this is limited by the motor. When the motor speed is high, a higher back EFM would against the input voltage to change the motor winding current. Please check the winding current. Can you increase the input voltage and check it again?
