Other Parts Discussed in Thread: MSP430F2617, , MSP430F2416, MSP430F2618, MSP430F2417, UNIFLASH, MSP-FET
Hi ,
I design a PCB with modify the DRV8886 EVM with almost same schematics for DRV8886 driving area except adding one more step down voltage regulator for MSP430F2617 power supplies,
when prototype PCB soldering all components on itself,I tested and found DRV8886 nFault pin keep logic low, cause alarm LED keep light on , during check the state of each pin ,I found the Pin of DVDD and AVDD pin voltage level quite abnormal compared normal state present in DRV8886EVM manual; I don't know why this happen although verify the soldering quality no obvious problem .
also met one issue when downloading program to msp430f2617TPM, software always post out alarm for the chip is msp430f2416 .something is wrong for my understanding , also attached alarm message. msp430f2617 order while display as MSP430f2416 when download.pdf
attached my schematics for reference,
MSP430F2617TPM+DRV8886 Version1.pdf
Will you help to figure out why and how to fix those issues? thanks!
Lin
