With the default 20KHz PWM frequency, I have a motor that is turning a wheel fine at no load (about 0.4A nominally) in one direction.
When we apply resistance to the wheel to test for our 3.5A overcurrent threshold, the motor driver gets very hot very fast, and stops from a temperature fault at less than 2A (peak current, as measured with a current clamp and oscilloscope. I would expect with basically the whole eval board as a heatsink that the part would be able to easily handle 2A without overheating.
We will try a lower PWM frequency and a heatsink, but it still seems to me that according the spec sheet and RDS on resistances, the driver should not be getting that hot at 2A.
The whole point of using a small part was to save space, and the need for a large heatsink defeats that purpose.
Would appreciate some guidance or advice on resolving on this behavior.
Chris-
