Part Number: CC2530
Hi All,
we are using the Zigbee-Lighting-Stack 1.0.2 . with stack core version 2.6.1 .
While i was trying OTA , it was interrupted by network and failed. Then the node stops communicating with the coordinator and also OTA can not be re-initiated unless we power off the node and power it on back again.
under the failure condition it will not act according to the lighting configuration that we send. Is this a know issue?? What are the possible solution to overcome this??
And is there any other OTA issue that we should take care??
Awaiting for the response.!!
Thank you
Avinash
