Part Number: DRV8308
Are there any alternative GUI support for DRV8308 GUI? Some customer is having admin right issue while trying to download the "GUI run-time" from:
Christina
Christina
Hi Adam,
The message indicates “There is an error downloading the file” and it's the GUI composer runtime.
Christina
Christina,
Here is the workaround:
1) Download runtime from http://software-dl.ti.com/ccs/non-esd/gui_composer/runtime/gcruntime-2.0.6-windows-installer.exe
The one from the link above will contain an .exe named “gcruntime-2.0.6-windows-installer.exe”.
2) Run the DRV GUI installer.
3) Choose appropriate application and runtime locations, but avoid spaces in the runtime path name.
4) When you see the following screen during installation, select the “Install from file” option, press the browse icon to the far left of this, and located the runtime installer named “gcruntime-2.0.6-windows-installer.exe”. Your screen should look similar to the screen capture below(except actual runtime installer version)
5) Press next and follow the instructions to complete the installation.
-Adam
