The datasheet mentions this in order to clear the overcurrent error:
7.4.6.1 Overcurrent Protection (OCP)
An analog current limit circuit on each FET limits the current through the FET by removing the gate drive. If this
analog current limit persists for longer than the OCP time, all FETs in the H-bridge will be disabled and the
nFAULT pin will be driven low. The device will remain disabled until either nRESET pin is applied, or VM is
removed and re-applied.
Can you please let us know what is the minimum time for which nRESET pin should be applied in order to clear the OCP condition?
Matteo Marioni
