I try to make a project with drv8304 and I have soldered the drv8304 but without the mosfets, I tested if SPI communication is working and now I want to solder the mosfet to start build my project step by step.
I measured without the Mosfet a voltage on SHx Pins about 13,6 volt. The device is configured as 3xPWM Mode and now I am not sure if the device working properly.
I supply the device with 11 Volts, is it correct to have voltage on SHx pins or maybe the device is destroyed during soldering?
Thanks in advance,
Nikos
