Hi, I am using DRV8353 for motor driver system.
And found 20kHz PWM Noise from the board.
I put 1uF value for Cbyp, and Cbyp is about 3mm far from the High side Fet.
Will this position will effect this noise? If I put this Cbyp closer to FET, then will it effect to reduce noise?
I think this is close enough but if this distance(3mm) will effect to noise then I will revision the board and make again.
Or Should I change the value of Cbyp? Do you think Cbyp's position or value will critically effect to reduce the noise?
Or Any snubber circuit should be added?
Thanks.
