Other Parts Discussed in Thread: TMS320F280049C, DRV8320, C2000WARE, C2000WARE-MOTORCONTROL-SDK, MOTORWARE, CONTROLSUITE
BOOSTXL-DRV8320RS: Need guidance on lab for DRV8320RS MotorControl SDK with TMS320F280049C
I have been going through the various TI instaspin motor control tutorials . I was able to run lab5 multiple times. Suddenly, I get the following error when I try to re-run lab5. Not sure what I am doing wrong. Please help.
C28xx_CPU1: Trouble Reading Register RPC: (Error -1044 @ 0x0) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 9.2.0.00002)
C28xx_CPU1: Trouble Halting Target CPU: (Error -1044 @ 0x0) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 9.2.0.00002)
C28xx_CPU1: Error: (Error -1044 @ 0x0) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 9.2.0.00002)
C28xx_CPU1: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
When I tried again after an emulation reset, I get the following error.
IcePick_C_0: Error: (Error -261 @ 0xFFFFFEFB) Invalid response was received from the XDS110. (Emulation package 9.2.0.00002)
C28xx_CPU1: JTAG Communication Error: (Error -1044 @ 0x0) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 9.2.0.00002)
