Hi
Is it allowed to supply only P12V to TPIC 2060A while in no driving operation?
(Stopped supplying to P5V terminal)
The purpose is to reduce power consumption.
BestRegards
You should be able to remove the 5-V supply. The RDY pin will go low once the 5-V rail is off.
If your goal is power-savings, the TPIC2060A can go into sleep mode when the XSLEEP bit is set to 0. In standby, the current requirement is only 0.6 mA. If you do this, removing the 5-V supply may not be necessary.
