I would like to ask you to give me your advice about following issues.
- VBST noise
Will you tell me how to reduce the ripple noise of VBST?
There is a not small ripple noise on VBST.
I thinks that using a bigger "C(boost) value" seems to be one of the solutions.
There is 0.1uF as C(boost) on the EVM and do you know the upper limit of the value? 10uF?
And if you know any other solutions to reduce the noise, please let me know.
One more question, please as below.
I know in case differential drive (OUT+/OUT-) woould be cancel the ripple noise.
But now I would like to drive a piezo with only OUT+ signal. (do not use OUT-)
In case of single drive, the ripple noise with OUT+ causes "noisy sound" from the piezo.
In my experiment, around 50V - 70V OUT+ causes bigger noisy sound than 90V out. (Vboost is 105V)
( around 50V - 70V is biggest, 20V and 90V are very smaller...)
I do not understand well why around 50V is bigger...will you tell me the reason?
Thank you for your support.
