Other Parts Discussed in Thread: TPS62110
Hi Everyone.
I have a question about power pad devices and what can happen if you rout and connect the exposed pad to ground as recommended in the data sheet but do NOT actually solder the exposed pad to the PCB. I don’t have any surface mount manufacturing tools so actually soldering an exposed pad is a problem. I’m referring to TPS62110, but can be any exposed pad device.
Cheers
kv
