Other Parts Discussed in Thread: TLC6C5912
Hi team,
I know this device is constant current regulator, but is it possible to use it as TLC6C5912 by using external resistor to set the LED current?
If I select the external resistor to limit the current lower than the current set by Riset of TLC6C5712, then I think the low side transistor will saturate and
the LED current will be set only by the external resistor.
Is my understanding correct?
Is there any concern if I use this device like this?
regards.
