Hi support team,
I have a question about Revision History of SNVSBA1B.
The following changes cannot be confirmed in Revision A and Revision B.
Is it a change from Original to Revision A?
Dice-K
Hi support team,
Dice-K
HI Dice-K,
The revision history details the changes that were done to the datasheet. For the TPS3840-Q1, the datasheet went through several revisions. Can you please clarify what is the question? The changes to the datasheet from Rev A to Rev B is listed in the picture that you provided.
Ben
Hi Ben,
Thank you for your reply.
From A to B, the changes shown in the attached figure are not found.
However, it seems that it has changed between the original and A.
Is the missing of the revision history from the original to A written in the revision history of Revision B as a follow-up?
Dice-K
Hi Ben,
Thank you for your support.
Is the correct Revision History as follows?
Changes from Revision A (September 2019) to Revision B
- Page-1: Added hyperlinks in section 2 of Applications
- Page-3: Replaced section 5 of Device Comparison Table with device nomenclature legend
- Page-7: Added note (3) in section 7.6 of Timing Requirements
Changes from Original (April 2019) to Revision A
- Throughout the document: Advance Information to Production Data Release
- Page-18: Changed the minimum value of the reset time delay from 80μs to 50μs
- Page-18: Changed equation 3 and 4
- Page-18: Added paragraph describing further details on capacitor
- Page-18: Added equation 5 and 6
- Page-23: Deleted non-relevant application design
Dice-K
