Hi Team,
There is a good news that we DIN LP87524J
Will there be any problems with LP87524J CLKIN floating? THX
Hi Team,
Hello Kygo,
CLKIN has internal 500kohm pulldown that effectively prevents this pin floating. So you can leave it unconnected if not used.
Thanks.
Tomi Koskela
Hi Tomi,
Thank you so much for your help & feedback !
More question,
At present, OTP is to enable PLL,
And there is no external connection, will there be a problem?
Hello Kygo,
No problem with it since the device has automatic clock detector and if external clock is not detected it will use the internal oscillator instead.
Thanks.
Tomi Koskela
