Other Parts Discussed in Thread: TLV62130
What is the difference between TPS62130 and TLV62130? Is it the same? Can I replace them with each other?
Hi ,
Amod will check the difference and reply later.
BRs,
Young
Hi HY,
TPS62130 are pin to pin compatible with TLV62130. But TPS62130 has some improved features. Such as adjustable output voltage can be 6V(TPS) vs 5.5V(TLV),
Lower quiescent current 17uA(TPS) vs 19uA(TLV), More tighter initial output voltage accuracy. You can replace them with each other.
Nancy
