Hi
The demonstration program code of SLUC600B and SLVC573B both use 62.260uA LSB for current calculation but the related TPS23861EVM-612 has 255mOhm sense resistors.
Shouldn't it be 61.039uA LSB as stated in the latest datasheet page 74 ?
Hi
Hi Urban,
Yes you are correct, the datasheet specifies the right LSB. I recommend if pairing the reference code with the EVM, the LSB can be modified to 61.039 uA in your reference code. Thanks!
