I am using the TPS3840DL49DBVR to monitor a 12V power supply for power down. I am using similar circuit to one on Figure 52. The difference being I have a larger resistor divider and no CT cap for the smallest reset delay. The circuit I have does not work as intended as the voltage at the resistor divider is 4.8V instead of 5.5V and the 4.8V volts in trips the reset at 0V all the time. What is it I am overlooking?
