Hi
Attached is the thermal imaging video of two different TPS51200A-Q1 on a sample
There is a temperature issue on TPS51200A-Q1, and the temperature will rise to 42 degrees after power on.
A new TPS51200A-Q1 has been replaced, and the temperature has not changed significantly after power on.
TPS51200A-Q1 is in the same batch, could you please help to check the reason?
Thanks!
