Other Parts Discussed in Thread: TPS2549, , TPS2546
Hi team,
My customer need a 10W type A that is dedicated for charge. Customer hopes the solution is simple and easy for design. Is the TPS2511 or TPS2549 suitable? Thanks.
Does your customer require cable compensation functionality? If not, I would recommend the TPS2546. I believe this is the easiest device for a USB Type-A source application.
Hi Adam,
After checking with customer, cable compensation is needed. Do you have any recommendations with cable compensation? Thanks
If you need cable compensation, then I would recommend using the TPS2511
