Dear Team
1. The customer have some questions of OCP, could you help to recommend?
From datasheet 7.3.4
Once the high-side switch current limit is reached, the high-side switch is turned off and low-side switch is turned on to ramp down the inductor current with an adaptive off-time.
1. Is the current limit detect every cycle?
2. If current limit is reached, will the ic auto retry to turn on the high-side switch at next switching cycle?
3. If current limit is reached, What is the time period form high-side switch turn off to switch turn on, is the turn off time of high side mos adjustable?
Many thanks
Denny
