Hi Team,
I see there is |Zka| in EC table, but want to check what's the effect to application on this parameter? For example, if there is another part but has higher Zka, what does it means? Thanks.
BRs
Given
Hi Team,
BRs
Given
Hi Given,
|Zka| is the dynamic impedance of a shunt regulator and it is an important spec because the higher the dynamic impedance, the more Vref shift you will see as you vary VKA voltage. This means |Zka| will offset the Vref voltage in direct proportion to the cathode current. To understand more about dynamic impedance, please see the link below:
https://www.ti.com/lit/an/slva445/slva445.pdf
Ben
