Other Parts Discussed in Thread: UCC2895, UCC28950
Dead time between gate pulses is set to 250ns but when measured using DSO I am getting around 500ns. after replacing the ucc3895 controller problem resolved, the same is happening 2nd time during the development process pleas help regarding the issue
equation (1) and (2) from the data sheet are used to set the above deadtime, looks like everything is correct from this part because replacing the controller solved the problem.
