Hi Team,
Is LP87524J-Q1's PGOOD default OTP set to open drain internally?
Hi Kygo,
PGOOD is open drain by default in LP87524J-Q1. The pin requires external pull-up resistor. The setting is reconfigurable through I2C.
OTP settings for LP87524J-Q1 can be found from the TRM: https://www.ti.com/lit/pdf/snvu663
Samuli Piispanen
