Other Parts Discussed in Thread: TPS2378, PMP11012, TPS23757, TPS23757EVM, TPS23758EVM-080, TPS23753A, TPS23758
i am planning to use POE PD interface chip to get power about 15W from ethernet, but I found that all POE PD interface chip need complex discrete components externally to get a dedicated voltage. so my question is:
if the POE input must be isolated from my own system power? and i must use a transformer to do that?
if i can use a DCDC buck converter IC to connect with POE PD interface chip to get the voltage i need? if yes, do you have any recommendation? i need 5V 3A power
