Part Number: TPS544B20
Other Parts Discussed in Thread: TPS544C20
This question is intended for both TPS544B20 and TPS544C20.
- Is it OK to write NVM while the device is in operation and the output is enabled? Does it have a negative impact on a device operation?
The device has to be mounted on PCB while writing the NVM. The input 12 V is supplied, the device is turned on, and the output is enabled.
Shinichi Yokota
