Hi
could you help check the TPS51117 schematic as below and any need to adjust
vin 12v ~24v
Hi
vin 12v ~24v
I'll check it and give you feedback tomorrow.
Andrew
Sorry for response delay due to some other urgent support cases.
My comments for the schematic:
1. Recommend to change C519 from 1uF to 4.7uF according to the recommendation on datasheet.
2. Recommend to add a 1uF cap between V5DRV and PGND.
3. It's strange that customer uses a 11A inductor with 18A saturation current and marked 22A for the rail. Please double check the inductor chosen here.
4. Since the I don't know whether the current rating and OCP is incorrectly marked on the schematic, I didn't check the OCP setting resistor. But that's easy to check with equation on datasheet.
Andrew
