Hi Team,
I just want to make sure how to allocate IC address to UCD3138A.
Datasheet describes its address is allocated by a resistor on AD00 pin.
Customer used to use one UCD3138A. And they use AD00 abd AD01 for current sensing input for their buck topology, not for address allocation. (I'm newly taking the customer and don't know much of design history.) It doesn't cause any problem for customer and I wonder how the address is allocated in this case. I guess there should a default address for UCD3138A even before the firmware download. Is it correct?
Currently, customer is going to use two UCD3138A. I guess they have to configure a resistor on AD00 pin to allocate two different address for each UCD3138A. Otherwise, there's no way to allocate the different address for each UCD3138A. Could you please check my understanding is correct?
Thank you.
