Dear team,
During some analysis, some unexpected conditions happen: driving the device with the correct signals to switch on IN + and IN-, once the IGBT is switched on, if they remove the IN- signal (transition from logic level 0 to 1), the gate driver does not switch off until the IN + signal is removed. This behavior does not correspond to the datasheet or in any case it is not explained.
Please could you support me with this problem?
Giorgia
