Are Altium design files available for the SM72295EVM?
(Design file package snvc222 only includes Gerber files)
Thank you
Thank you
Hello Eckart,
I checked, and as you mentioned I do not see the design files available for download. This part is one of the older devices, so it is not clear if the design was completed in Altium at the time.
Hello Richard, thanks for your quick response. I did notice in the lower right hand info block of the design schematic (SV601191B-001_Schematic.PDF) that the original filename has extension .SchDoc which is typically used by Altium. Based on that I am guessing the design was completed in Altium. It also gives a name of a designer engineer Ambreesh Tripathi. Would it be possible to inquire if he can make the requested files available, assuming you are able to contact him within TI?
Hello Eckart,
I can look and inquire, but there will likely be a concern with putting non web released files on the open forum. And there may be an issue finding the files. If I can locate the information, you will need to friend me for this discussion in private.
