The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
TPS2041B-Q1: What's the difference between TPS2041BQDBVRQ1and TPS2041BDBVR?
Part Number: TPS2041B-Q1
Hi Team,
All spec the same except temperature range and AEC-Q100 qualification. Thanks.
BR,
Molly Huang
  • Hi Molly,
    You are correct. The only difference is the Q100 qualification. The version with Q is for automotive which requires much stricter qualification.
    For others, both are same.
    For TI's policy, I will first click resolved button.
    If you have any other concern, contact me any time.
    If you think resolved, please help click 'Issue is solved button'.
    Thanks.
