Other Parts Discussed in Thread: LM5176
We are currently using the LM5176-Q1
Regarding the DRV voltage driving the FET connected to the LM5176, the spec doesn't seem to clearly state it, so I'm asking for confirmation.
As shown below, it is explained that the low side is operated with VCC and the high side is operated with the voltage of Cboot. (page.18)
If you look at the VCC voltage as shown below, it is shown that the voltage range operates between [ 6.95, 7.88].
If so, does the gate voltage on the low side and high side turn on the FET with a voltage between [6.95, 7.88]?
In addition, please explain where to check the range of the voltage shown on the gate when the FET is off.
In other words, the voltage range that turns on/off the gate of the FET is not clear, so I ask for confirmation.
Best regard
Thank you
