I'm trying to make a 24V buck-boost power supply and can't find the problem why it isn't working.
I already found that:
- Q4 and Q7 are placed in the wrong direction.
- R40 has the wrong value.
The 2 NMOS had been replaced and soldered correctly. The resistor R40 is replaced by a 24kR.
VBAT is 29V during the test. The voltage at the EN/UVLO pin is around 5V and should be enough to activate the LM34936. There is no switching happening at the gates of the MOSFETs.
Does someone have an idea why it's not working?
Radomir
