Hello Team,
I'm having design activity with my customer and their OEM requested below information. Could you check for each of items? Full PN is TPS7B4253QDDARQ1.
1. Encapsulation / Housing Material
- Encapsulation/Housing material information is requrested because it the major contributor for the thermal expansion properties of the part. In addition Encapsulation/Housing material can be affected by High Temperatures and humidity.
2. CTE
- This is the overall CTE (coefficient of thermal expansion) of the part that will induce stresses on the solder joint. This information is needed in order to determine if testing for thermal fatigue is needed.
3. Soldering profile part rating
4. Max power rating
Thank you.
