Customer designed BQ78350-R1 with a 14S14P for personal mobility device, and need to characterize it.
What temperature and discharge current setting to be used when logging the 6 discharge data for the gauging coefficients?
There is a need for 3 different temperatures and 2 different discharge rates:
- Temperature: Is it best to use ambient temperatures closest to the actual usage of the mobility device or use the highest, lowest and room temperature?
- Current: Load current surges & varies significantly. It is not a constant current usage scenario. How can we correctly choose the discharge current to be used to make the coefficients as accurate as possible?
Can you suggest best possible way to make the BQ78350-r1 as accurate as possible based on this application?
