TLV752: I only need one of the two channels
Part Number: TLV752
Hi Team,
May I ask for your confirmation? My customer concern is stated below:
"I am using a TLV752 in a design, but I only need one of the two channels. I could not find any guidance on what to do with the other channel in the datasheet. I was planning on grounding the input and enable pins for the second channel while leaving the output and fb pins floating. Is this correct, or is there a different recommendation?"
We will wait for your response. I hope you can help us. Thank you so much.
Kind regards,
Gerald
