As we are using LM5146-Q1 IC, and in datasheet it is mentioned that we can give external supply on its VCC pin but may we give its owns Output voltage as external supply to its VCC?
Hi Aman,
You can give its own output voltage as external supply to its Vcc as shown in datasheet Figure 8-2, but you should ensure that the output voltage is within the recommended operating conditions in the datasheet, which is 8 to 13V.
Xiaoying
