Hi team,
My customer use bq29700 in their project. They tests the battery reverse connection protection. Customer connect 330ohm resistor on BAT pin. When battery is reverse connection, customer measure about the current 300mA current through VSS. Why is the reverse current so high?
Is there a TVS between BAT and VSS? When battery is reversely connected, the TVS will be forward bias and the current flow through bq29700 is [V(bat)-V(TVS forward bias)] / 330ohm. Is the analyze right? Thanks.
