I had earlier requested a design review here for my TPS652353 design.
Now my board has arrived and I wanted to check the output voltage by setting it through I2C.
My input voltage is 5 Volts, I have connected VCC and VIN pins together as per the datasheet.
However, when I check the output with DMM it is at 3.2 Volts always.
I checked the status register and CABLE_GOOD and VOUT_GOOD are low.
Is it the case that without a proper load like an LNB or dummy load the voltage will not be set?
