Hello Experts,
The datasheet mentioned "The UVLO resistor divider must be designed for turn-on below 6V." Why it is restricted? Can customer set UVLO above 6V?
Fujiwara
Hello Experts,
Fujiwara
Hello Fujiwara,
This sentence can be found in the application section and the parameters for the application that is described here can be found on page 21. The minimum input voltage shall be 6V in this case, so for this case the UVLO must be below 6V.
You can set the UVLO to the voltage needed in your design.
Brigitte
