Part Number: CSD16401Q5
Other Parts Discussed in Thread: CSD16415Q5
need CSD16401Q5 MCD
need CSD16401Q5 MCD
Wells,
Thank you for your interest in our MOSFETs.
As the CSD16401Q5 data is not on the TI website I am working to get this corrected ASAP.
if you can not wait for an answer then I suggest you use the CSD16415Q5 which is on the web here: https://www.ti.com/quality-reliability-packaging-download/report?opn=CSD16415Q5
The only difference in the CSD16401Q5 and the CSD16415Q5 is that the weight of the silicon will be a little less in the CSD16415Q5, apart from that everything else is exactly the same.
Many Thanks
Chris
Wells,
There is a section in the materials table for lead frame plating, this gives the Tin content.
| Lead Frame Plating
Other Nonferrous Metals and Alloys
Tin
7440-31-5
0.2
100.000000
1000000
0.158188
1582
