Other Parts Discussed in Thread: UCC28950
How are you ?
How to control the load sharing regarding the connection of the two parts.
Is there a circuit diagram for the UCC29002 and UCC28950?
Carson,
could you refer to below thread? it may help you to understand the connection.
Yunsheng
Hi Yunsheng,
Thank you for your reply.
After reading the specification the recommended maximum voltage for the adj pin is VDD,
If S+ is 24 Volt , how to connect the adj pin ?
Hi, Carson
You can refer to below diagram which is for high output voltage application.
Yunsheng
