could you help to comments on whether below SW waveform is normal when LMR16030S work in light load mode.
below is the waveform.
1. does it make sense?
2. the reason that cause the spur before pulse.
Hi Shuang,
At DCM condition, the inductor will resonance with SW node parasitic cap after inductor current decrease to zero, that's why you see the ringing before HS turn-on.
Pls check the SW waveform at higher load current to see if the duty cycle is stable.
B R
Andy
