Hi team,
What could be the problem behind the fact that I can't get more than 5 volts at the LDO (TPS7A2050PDBVR) output with 5,8 volts at its input. The capacitors used at the input and output are 22uf mlcc.
I managed to get 5,2 volts output when applying it in one of the devises, but when I followed the same conditions in another one, I only get 4,9 volts.
Could you please advise a solution to this LDO behavior.
