I'm trying to get the SOH of my battery from the charger board over i2c, however I'm getting confused by reading the data sheet!
I am able to get voltage, SOC etc. just fine, but the section on SOH is different.
https://www.ti.com/lit/ug/sluua35/sluua35.pdf?ts=1629446576002
page 13, section 2.15
It says that the command to send over i2c is 0x1C. Under 2.15 it starts mentioning "0x28" and "0x29". What do these mean?! Am I reading from 0x1C or from 0x28!? What exactly am I supposed to be sending over I2C?
If you look at all the other commands, for an example 2.14, it lists the command to be sent over as 0x1A - and it works fine. I'm utterly confused as to what the manual means by writing that the command to be sent over is 0x1C and then all of a sudden starts mentioning 0x28...
