We want to use the LMQ61460-Q1 for a 1V/2A output option , with 12V input ( it is the minimum output voltage that is possible according to the data sheet). The WEBENCH doesn't support this option ,
I receive the following error:
Can you please check if this converter is compatible for this application?
If not, what other options do you have which are automotive and has a high efficiency?
Thank you for your support,
Anna
