Other Parts Discussed in Thread: TPS737
Hi, support team
My customer need a replacement of TLV75733PDRVR.(PIN to PIN)
TLV75733PDRVR is found, but TLV75733PDRVR's Pin2 is NR when use in Fixed voltage.
Datasheet write "connecting an external capacitor to this pin bypasses noise generated by the internal bandgap, reducing output noise to very low levels."
Could PIn2 left floating when use in Fixed voltage (not connect external capacitor)? (Replace TLV75733PDRVR directly PIN to PIN)
If it can't, could you recommend a replacement of TLV75733PDRVR PIN to PIN?
Thanks so much.
Yuki
