Other Parts Discussed in Thread: LM5170
Hi team,
12V / 48V is written in the application example of the datasheet.
Does this device work only at 12V / 48V?
If no, could you tell me how to change the output voltage?
Sincerely.
Kengo.
Hi Kengo,
Thank you for your interest in LM5170.
No, LM5170 can be used for other voltages. 48V/12V is just a typical application. Please check the datasheet 7.3 Recommended Operating Conditions for the operating range. As LM5170 is a current controller, the voltage regulation is designed with the external feedback circuitry which is usually a resistor divider. By adjusting the resistor divider it regulates to different voltage.
Yinsong
Hi Kengo.,
For the first question, which case are you talking about? Still 48V/12V?
The Quickstart calculator can be found here.
https://www.ti.com/lit/zip/snvc205
Yinsong
